So I just spent 6 hours in this damn cold ass weather working on my new cause of pain and suffering. :lol: Well actually it was 7 hours but I am not counting the two times I took a break so I could stop the bleeding. :lol:
I swapped the cup holders out... what a PITA!! The colord piece is glued in place to the holder assembly so I couldnt just change covers and swap them over. I had to break the glue apart and use some CA plastic glue to get them back together, I also managed to break a tab that holds a spring so one side wouldnt flip out. I rigged it though and modded the cover to clear the screw I put in. Works great and now I can have a drink in teh car.
Also swapped the spring for the console lid and then found where that little string was that hooks to the glove box dampner and got that hooked back up so the box operates smoothly.
After all that I worked on the seat. It appears the sensor on the motor is broken and wobbles around so it limits the seats travel. I swapped out the track with the 97's and that corrected it. Also the passenger seat belt reciever was broken but when I had the track upside down some glass fell out of the latch. So I shook the rest out and the seat belt now works again.
That led to the next problem of the seat belt not wanting to come off the track and I didnt want a tan one in the car. :lol:
I had to use my Ingrosol 3/4 impact with the pressure at 150psi to break that bastage loose.
But finnaly got that done too.
After that I swapped out that C&L MAF and open filter to my stock box from the 97 and stock MAF.
Then I removed the SCP braces from the 97 to install on the 98 but it ot too dark and way too damn cold to continue on.
Tomorrow I will sensor lower the front, install the braces and the Addco sway bar. For now I am freakin beat! :lol:
Ahhh, the joys of Mark ownership.
The sensor on the end of the center motor was what went bad. Looks like a PITA to swap though so I just swapped tracks.
Here you can see where the two parts seperate for the cup holder. I reglued those black spots. You can also see my ghetto spring fix.
So after 7 hours and an amazing amount of blood I have a working seat, working cup holders, working console spring, working dampner on the glove box and a stock air box.
