MsM8tress
ok - JD has pity on me and sells me Tux back (he has that HUGE truck after all) for two weeks the air ride has been fine, compressor fine, spyder valve fine, raise/lower fine...then all the sudden the compressor starts running the entire 90 seconds and sounds TERRIBLE (no raising occurs), right after it shuts off the check air ride comes on? I check the valve under the hood, it reads ZERO air pressure...?? Should I put air in???
forgot to add he looks to be sitting at normal height, maybe a little lower. He has not been slammed but don't want to wait till that happens.... AND I just checked the valve again, now it reads 163.... he is gonna make me nuts. but still looks a smidge low...
I did search, but no guidance on should I put air in? Checked bags they seem to be holding air fine... Wondering if I should go to a shop and have them lift the body off the frame, maybe a pinch some where??? I DUNNNOO...
:Bang:Bang:Bang:Bang:Bang:Bang:Bang:Bang:Bang:Bang:Bang:Bang
I gotta go to the gym then run 4, I will be back, thanks in advance!!!!
