stihlboy
i shall be discussing this matter with them in great lengths tomorrow
This is why I say to use a MOTORCRAFT thermostat only. In the pic, the stat on the right is the Motorcraft stat and the one on the left is an autozone stat. Note the size difference in the opening coolant flows through. Any stat from any parts store will be the same as the left one. I've seen at least 20 Mark VIII's with overheating issues be solved with a Motorcraft stat. What I can't explain is why some Mark VIII's are able to run the smaller stat without a problem.
So far - Tux is staying cool....
Will let you know on the burping also, havn't received the funnel yet... wondering if I should screw with him if he is acting ok....
