Sapperfire
Yes you do, you wanna see it look like your old one, one day...
But mine will be a bit more customized
Man you should go demand a refund from the idiot that put the old gasket on there!
Wanta do another one![]()
If you take the valve cover off, why not replace it?
...and if you're going to spend 4 hours removing these type of parts...
Usually once a gasket such as an intake/valve cover/oil pan/ect is smashed...you don't reuse it...and if you're going to spend 4 hours removing these type of parts...you'd be a fool to reuse the old gasket and risk it leaking
He's slow...... and did it the slow way. :lol:What's so different about the gen 1's that makes it take longer? 4 hours to remove valve covers? Took me like 30-45 minutes on the 2 gen 2's I've removed them from.
Just curious...
he is speaking from experience....he spent about 2 days putting a motor in to find out it didn't run.
