Sapperfire
Now I dun gots me both them Gen cars, I gonna jump all round now and be all woohoo, woohoo, yeah I likes em both styles, woohoo
Yeah, except the record the T-bird took, E/F SS isn't the one I wanted to keep. The record I set, raised, and then I raised again, E/F CC was set with only a light hit of spray, turned on just as the transmission went into third gear. Because I've been concerned about the powdered-metal rods, the cast pistons, and the hundred-thousand plus miles on the engine and the fact that it really is a daily driver, I was content, at that time, to take it quite easy. As I said back a ways, the turbos are on the bench in the garage, never having been mounted yet.
One of the nicest things about the combination of spray, methanol, and a pair of turbos is that with the bottle, and the methanol fuel pump switches turned off, and the little knob that adjusts the waste gates turned down to 5-6 pounds, the engine will act very much as if it were one of the Jag 'R' engines and make about 400 HP. But if called on, all it takes is a flip of the switches to open the bottle, turn on the heater, and start the methanol pump running. And then with a twist of the WG knob I can have 1K++ of power. It's all a DEMAND system, you see! I can have my cake and eat it too!
KS
See there in lies the problem. In order to run properly you cant just turn a knob. You will need to tune the ECU as well. If you are running on a tune for 30psi and then crank it down to 6psi the car will fall flat on its face the moment you give it the beans.... or really anything past 50% throttle. Sure the tune reads MAF AD counts but it also looks at throttle position (yes a dozen other paramiters too) and when its tuned for that boost hit the car is gonna spray way too much fuel for that and also the timing curve will be limited based on the higher boost numbers.Yeah, except the record the T-bird took, E/F SS isn't the one I wanted to keep. The record I set, raised, and then I raised again, E/F CC was set with only a light hit of spray, turned on just as the transmission went into third gear. Because I've been concerned about the powdered-metal rods, the cast pistons, and the hundred-thousand plus miles on the engine and the fact that it really is a daily driver, I was content, at that time, to take it quite easy. As I said back a ways, the turbos are on the bench in the garage, never having been mounted yet.
KS
All mark owners who bash the LS need to read this post...
The transmission is a ford product same as used in the mustangs.
The chassis and suspension are all Jaguar as well.
If you look up pictures of the s-type you can see how closely related they are.
Mark owners are WELL aware that FoMoCo likes to cobble cars together from the ol' parts bin.
And being related to the S-Type is not something you want to advertise. At least it's not the X-Type.
Doesnt bother me.
I like the s-type interior just not the exterior. The str is pretty damn fast and can run 0-60 in 5 seconds. I would have got one but i like the looks of the LS better.
Only Jags I like are these. Can't stand the rest. Those 80s and older XJs are rot boxes - I'd never touch one. My uncle had a Daimler Double Six - was OK, but expensive to keep on the road.
ford should have kept jag.
+1. Jags are cool, but you have to have two because one is gonna be at shop.I don't know, I think they did good by selling Jaguar. It didn't sell all that much and now they can focus on Lincoln, I hope:shifty:
Before I get to carried away? You just validated what I said. So now you are pissed cause we agree? You just said if you need to change it then you would hook a laptop up to it and change it. Thats pretty much what I do to mine too. Its just you wont be flipping a switch, you will be reloading the ECU. No biggie.
Then on this pissing contest. Why do you always change chit when I meet your throw down? You said run a mile. You said you run 140 in that mile. You said my car couldnt beat that. You then say that it dont matter cause you can gear down. :lol:
FYI, my car has a full 18 gallons in it (just filled up), big ass honkin sound system, spare tire, tools, and my fat ass.
You now need to change crap to make yours faster? So what? I pull the system and tools and spare and run a half tank and will run faster yet again.
You say yours is a lowly safe tune cause its a DD? So is mine! I run a very rich 11.3:1 AF at WOT and only command 16.5* total timing and have a modest 7.4 psi. As you see I have a very safe tune too. My fuel pump is at 60% and my MAF is at 63% so I have room to add several more lbs of boost too.
Dont offer to run and then say you cant. Dont decide what I say we should run is wrong and that you only want to run a mile and then dismiss the fact that my car runs faster then yours (right at this moment) due to BS excuses. Thats so freakin rice. I expect that from a Honda owner. Next thing you know you will say lets do a roll on from 20 MPH! :lol:
The way I see it is that no specific car owner is any more well spoken, or written, than the other. There are idiots and scholars among any crowd, regardless of car model. Arguing back and forth over who's car is faster makes you both look childish and undereducated.
Here's a new topic to stir the pot: Spray is cheap and you are cheating!
Geezly Mike---
Way to hurt a guy's feelings. "...undereducated..." D'ya mean all that time I spent in school...?( At least I don't misspell words!)
As far as the new topic, I never added up the money I've spent on the system, and I'm sponsored by NX---Nitrous Express, so that would cut into what I had to lay out. But five gallons of methanol costs about fifty bucks, and a tank of spray about the same. (I've got six tanks) Then you've got the Fuel cell in the trunk, with the pump, filters, pressure regulator, gauges, and the controller and about a hundred feet of assorted -4, -6, and -8 Teflon SS braid hose and all the fittings that I did pay for.
Nah, not cheap!!
KS (Laser just seems to get more frantic as the day wears on so I'm just going to let the whole fracas set until this summer.)
