BAD97LSC
well, here is the deal so far, the motor was delivered today by pasco auto salvage, the car was towed in a little later. i got to my shop around 4:30 and just about laughed and cried at the same time when i saw the motor. first off, motor is clean, cant argue with that. pasco auto salvage are :q:q:q:qing hacks, cant argue with that either. the fuel rail is bent 90 degrees toward the hood where the fuel lines attach, exhaust was cut off with a torch, which melted the right 02 sensor plug, they cut the smog pump pipes off, they broke nearly every plug on the engine, they stole all the coil packs off, the ac compr, the power steering pump, the alternator, i had to remove the entire engine harness from it, and replaced it with one i had kept off one of my motors, so thats allset now, i am pulling the intake off to replace the fuel rails and injectors, i am not taking a chance with the injectors the gas has a bad tarnish smell, so its easy enough to just change the whole dam thing, i have to swap some stuff over from derrik's old motor to the new one, accessories and driver exhaust manifold and cat, dumb stuff. its funny how i remove these and then to see how a junk yard removes them my god, fully dressed is supposed to mean a turn key replacement, this is far from that, extra work for me now thats all, derrik just has to wait longer!!!
i'll be taking alot of pics as i go along. i have a really severe headache tonight so i came home early to get some needed sleep, i'll be at my shop around 5:30 am tomorrow so i can get his motor and trans out, i'll have it all out by lunchtime hopefully then i'll wait for derrik to bring me parts!
