Sergmark
Cool,
Looks hi tech. Wonder how it's going to ride...:shifty::shifty:
Yep. That's the idea.
Stangman, no-no. The manual fill option is there just in case. This strut was originally designed for use with the factory system. The shraeder valve was just an afterthought.
The reason I'm having something made to accept a factory solenoid, is because some people want a factory setup. (plug-n-play) For the time being, if you want the bigger, aftermarket solenoid, you'll need to splice 2 wires on the front solenoid.
The aftermarket solenoid has a different Ohm reading than the stock solenoid, so I was thinking it may kick on the check suspension message....but didn't have any problem in testing today(knock on wood).
Fordnut, billcu is just testing the prototypes. If everything goes ok, you can order a pair and have them on your doorstep in 2.5 weeks.
Stangman; So said:Absolutely.....and i'm sure it'll ride different....either harder or softer, but the ONLY change I figure they'll be is that it'll vent freakin quick! Due to the 1/2 inch hole going into the air spring and the bigger solenoid.
Eddie.
If testing goes well. Ill send a check for a set.
Let me ask this question a different way... What are the characteristics of the shock absorber inside these new struts...? Harder/softer than stock? I'm wondering because I know some people, myself included are after a stiffer shock absorber. Any insight on this? Thanks!
Still wanna know what the shocks are like... :shifty:
