Markviiiedrea
Speed Bump
As stated on another thread, this hopefully will be a collective of wheels/tires that people have successfully put on their Marks. This can be anything from using a wider tire on factory wheels or rims with slicks on them.
So let’s keep it simple. Only post wheel and tire combination that you have actually used and had success with. Also if you had to hub swap, roll fenders or you have it lowered. A picture would be appreciated but not necessary
If you can’t supply all the information please don’t post until you do so there won’t be any questions about that combination. Please start another thread if you want a discussion about a certain combination, let’s just keep this to facts.
So...
-Brand of rim (American muscle, factory 04 Cobra, Ford racing )
-Size of rim (width, bolt pattern, height and offset. Exp, 9",114.3x5,17,36mm)
-Tire brand (firestone, Goodyear)
-Tire size (255/45/17)
-Modifications (i.e. hub swap, fenders rolled, stiffer shocks, sway bar used, lowered or not, or other info that allowed you to use the combination)
* Moderators please make this a sticky, or if you think more info is needed please edit.
So...
