NoLimit95
This will end up on page 15 with links to 2011 amps and subs at the rate he's going. The setup you just mentioned would beat his brains out though.
Buy one more and run four in a sealed box. Then the amp could be run at 4 ohms mono.![]()
Thanks Laser and yeah, I'll give them time to get used to me. As much as I play this thing, they may never be broke in. Right now they have about 10 minutes on them, if that. I'll try to go ahead and get the burn in out of the way the next time I go somewhere.
If you run across a deal on some 2 AWG on the bay, let me know. $1.68 a ft. is the best I have found so far. I think 18 foot should do it and I would like for the same place to have 4 gauge too so I get it all at the same time. I have a 2 gauge firewall grommet and everything else, just need some wire now.
Remove caps or no?
You should run a series-parallel config, run two subs in parallel which will give you 2 ohms and then run the third in series with the other two, bringing your total load to 6 ohms. Lower impedance = more power out of amp!
oh.... well earlier it was at 400, figured it was gonna be jacked up soon... oh well
Remove caps or no?
