dnsherrill
93,4,5 can work, need to swap the entire housing assembly..then I'd need to get my tune modified to cancel the DTC
Do I want this? probably not...fun to think about though...Mark IV 460
http://atlanta.craigslist.org/nat/cto/3630853619.html
silly question #1,284 (before I cough up $200)
....coils that fit a T-bird/cougar 89-97 are for MN12 and will work on my '96 M8...si senor?
found some locally, 1'' drop
found a 95 for parts....got some already, going back for more...should I get:
- ABS pump and/or module
-blend door actuator and or blower motor?
- if yes on the blend door act, can I just cut the dash away and get right at it from the top?
this car also had the phone completely intact in the console
this car also has the phone completely intact in the console
----No idea how you can get it out of the armrest box, but it should unplug quite easily. I do need everything that comes with it though, which basically means any cable that you find in that box and the frame or clip or whatever is used to hold it in place in there. I only have a connector I can plug the phone in at the bottom of the box, the rest is missing. Maybe you find an instruction manual in the glove box, Id take that as well
Also, do you know in which condition the taillight on the trunklid is in?
parts off a 95 LSC, thinking about getting bumper covers and door/fleet trim pieces. Is this pass side trim reusable???
http://atlanta.craigslist.org/nat/cto/4045036303.html
btw, this seller is asking 1400 for the entire car..wrecked with no windshield :lol:
