EDIT: Whats in your trunk..emerg items ect
Lownslowlsc
N il
Just curious what yall keep in there in case of a emergency or for routine car needs.
I have: (in my cargo net)
Emerg kit with jumper cables, bungy cord, fuses, basic tools, knife, superglue,flashlight
Antifreeze
oil
windsheild washer fluid
2 cops just incase
tire preasure monitor
tape
fire extinguisher
i also have 2 type r"s in a blow through and a custom amp rack houseing my sub amp,compass module thing and stock amp attached to the rear seat brace.
umm...right now, there's a screwdriver, a cue stick in it's case, and a 100-something bit set from Harbor Freight. Sometimes I have my Mag-Light in there, but not right now.
No net, small tool box, fire extinguisher and under the spare tire cover, I have two belts and the pry bar to change them just in case. Also going to add another extinguisher that's smaller to go under there. When I put the system in, that's all I want to show in my trunk, amps and subs only. I'm afraid of fire now.
NM.
In my CARGO NET there are some micro fiber towels and some quick detailer and quick wax.
In the rest of the trunk is a Boston G5 10" sub, JL Audio 500/5, Spare tire, jack and emergency mini repair kit.
i have a box with 2 ten inch JL's, and a box from ford with a brand new blend door in it, thats it, i dont even have a spare!
ok,well.....My intentions were for poeple to list emerg items ect but o'well
doesnt he though...I guess poeple can list that type of stuff to.
i give up.
Well I first thought you just wanted what was in the net but after re-reading it seems your title would imply whats in the trunk as well.
guess i could've explained it better but o'well....title has been edited.
Still after the title has been edited... Other than that spare tire where it should be I keep a wood Louisville Slugger bat.
I have my cali car duster, some quick detailer with a micro fiber cloth, water blade, chamois, and jug of washer fluid in the net. Besdie my spare I have an extra serp belt and one wiper blade, and a large towel/cloth and pair of gloves...
antifreeze, spare belt, miscellaneous tools, a 5 disc changer that doesn't work, quart of transmission fluid, quart of oil, washer fluid, tire pressure guage, blow up doll, small snow shovel, 50 pound bag of ice melt extra gloves, hat sweatshirt (winter only).
you gotta have that blow up doll for when the shovel and salt cant get you out of 12"s of snow...Got to keep yourself busy.
Derek you are about ready to be loading 24 paks of pampers in the net, arent you?
But seriously....
I have one of those mini emergency road kits, but have it strapped off on the side, and in the spare well, Heavy Duty Jumpers,
and in case of a flat, some towels and gloves and a couple of bottles of water as a emergency tire changing kit and the 2010 SI swimsuit issue so I have something to read while my wife changes the tire.
4 rifles, and 2 handguns.
My F-class .308
.338 lapua
22-250 savage ftr
and a Winchester .223.
Springfield xd40
Ruger .22 bullnose target pistol.
They will be out in a minute, I just got done at the range and haven't brought them in yet.
There may be some jumper cables but I'm not sure.
