ripped camel
I swear I've thrown so much damn money at this car and it still is far from driving right. I switched in a new computer on Friday and it drove a thousand times better...for a few days. Now it's doing the same erratic crap it was doing before.
1. Sitting in park it was revving all by itself up and down from 500rpms to 800 rpms, whatever the hell is causing that.
2. It hesitates horribly and feels like it is sackless.
3. From a roll if I dump on it, the car feels like its standing still and barely wants to move. It used to go like an animal from a roll, now I'd be lucky to beat a Corolla!
I will say my old computer was throwing a IMRC code and a Lean O2 sensor code. The new computer is mentioning failed catalyst and O2 sensor again. It hasn't brought up the issue with the IMRC yet with the new computer. So that really confuses me.
All of the following parts are new and changed within the last 2,000 miles:
Motorcraft fuel filter, SVT focus 255lph fuel pump, Crankshaft position sensor, plugs, all boot were checked and cracked ones were replaced, swapped out the IAC for another used one and cleaned it thoroughly (although it is used so that still can be the issue), Cleaned the TB, PCV valve, Hand cleaned IMRC's, new ds head gasket, oil gasket, valve cover gaskets, swapped to a 98 trans, Mach 1 torque converter, J-mod, all new fresh fluids.
The problem was there before I did any of these mods so I know none of the above caused the problem (so it's not the 98 tranny causing the issue). The cats were gutted, and not long after is when the problems started. I know it should run fine because Kooks delete the cats so there should be no difference in driveability, and my SCT will not delete the O2 sensors. Both Reinhardt and SCT were unable to get my O2's to be deleted.
So I'm at a loss what to do with this thing. I've got WELL over $5000 invested in this car....probably upwards of $7000 by now! I could have had my Mustang back for that kind of money.
Any ideas on what else could cause this? I'm truly at a loss....
Jamie feel free to chime in and mention anything else you did or can rule out, so we can better diagnose. I think I got it all though....
