BAD97LSC
figured the old post turned into such :q:q:q:q, i'll start another. well, we refurbed one of the heads i save from a 97 motor i had. checked it all out, surfaced the head and cleaned it all up. put a new head gasket on the block and slapped the new head on with new bolts derrik had his buddy run up to my shop today. special thanks to tommy for helping me out over the phone with the torque sequence on the head bolts. i actually just had my buddy tell me what to do as far as getting the timing chain and gear back on correctly, it was cake. i cleaned the imrc's tonight got them real clean and i tossed the timing cover in the parts washer and hit it with an air grinder with a special bit in it that holds a piece of scotch brite and whips it around real fast. its all re-assembly now, should be done sunday, if some dip:q:q:q:q leaves me alone!
