elephantrider
looking forward to some pics !
Dam your LS is clean under there. Nice work. Let's see lowered photos!
It's easy when winter consists of 3 days of rain in December!!!!!![]()
I actually raised her up from Eibach level - LOL - prob the only one who will do that!
I actually raised her up from Eibach level - LOL - prob the only one who will do that! The Pics on prior page are essentially the current stance but I have removed the 1/2" rake.
If I ever go with Eibachs, I plan on adding a 1/2-3/4" spacer to lift the car a bit, assuming the spring seats are semi-flat
...I wanted the LS higher after buying the C7 as my sports car....
Not the only oneI had Eibach with spacers for a few years before getting Stance.
Do you happen to remember the dimensions for those spacers? What material did you use? If/when I go the Eibach route, I'd like to just make it a straightforward installation
Question for those aside from myself that have Stance Coilovers. Anyone experience a small vibration via the steering wheel at 60 to 70MPH? I typically notice it on asphalt surfaces with undulations. To me it seems like the feedback is too precise - I currently have the dampening set at 3 front and 2 rear. Adjusting damping higher or lower does not seem to have any real impact. It is slight but I notice it and have had the wheels rotated and balanced on more than one occasion. I am wondering if Deaconblue could be on to something with the high spring rates - does anyone think some lower spring rates might assist? If so what lower rates would be recomended on a heavy vehicle like the LS? Any other ideas or suggestions would be appreciated. I understand when you move away from how the vehicle was originally designed these things are not uncommon. Overall I am very happy with the coilovers from a ride quality and performance perspective.
Had my Stance coilovers installed a few weeks ago and just went on a 900 mile road trip. I currently have them set on 1 in the front and zero in the back and would say at this setting the ride is slightly softer than on the Eibach's. Actually raised the car from prior Eibach level by about a 1/2" since I wanted the LS higher after buying the C7 as my sports car. There is a 1/2" rake on the car that I plan to remove after everything has settled. Also had the Senta knockoffs powder coated a slightly darker color from silver to silver gray. Very happy with the new ride as the coilovers control the 20" Senta's much better…felt rock solid at 70-90 mph in the AZ desert
But I do have some concerns and hope that some folks who are using/ have used these Stances can verify for me:
1) There are no fitment issues?
None
2) The Stance shock ride height is appx same as factory? (I do not want to lower the car.)
You can adjust them up to stock height if you wish
3) They ride stiffer than factory I would assume?
On the softest setting (1) they are just a little stiffer then OEM.
4) Did anyone buy the 'swift spring upgrade'? And if so, why?
Not that I have seen. Could be wrong
5) Are you happy with them? I know one person had one fail. Has anyone else had a failure?
Have had them since the first set was shipped out. Still very pleased
received_10104399335917584 by Justin, on Flickr![]()
received_10104399368402484 by Justin, on Flickr![]()
FB_IMG_1467314091591 by Justin, on Flickr![]()
Wow another stunning LS. And thanks for the quick reply. Course in the meantime I thought of a couple more questions:
6) The car I will be putting these on came with the Sport suspension and is a V6. Are the Stance's designed for V8? If yes, will they still work OK on my lighter car with sport sway bars etc? Since they are adjustable, this might be a moot question?
Wait, really?
Moot point. Nothing to worry about, they will be fine.
