Deaconblue
If you have the spare cash these are the very best ramps and are very easy to use.
http://www.raceramps.com/
They are sturdy and take most of the fear out of using ramps. The fact that they are modular (sort of like Legos) means you can drive the car up on a set of them, then remove the center sections to make it easy to get under the car to work on say the exhaust.
BTW, my driveway also slants up to the garage so it makes some things easier, like draining fluids or filling the coolant system. You just have to make sure you use wheel chocks to be safe. Since its a circular drive there is a flat section in front of the house which is better for checking fluid levels and other maintenance work.
