Telco
And finished. They sent me sway bar links, not tie rod ends. Bummer.
![20131121_181850[1].jpg 20131121_181850[1].jpg](https://www.lincolnvscadillac.com/forum/data/attachments/72/72172-6ebafe8bd67dd53f7efe28492568f321.jpg?hash=brr-i9Z91T)
![20131121_181910[1].jpg 20131121_181910[1].jpg](https://www.lincolnvscadillac.com/forum/data/attachments/72/72173-68d6aeed4117732648209aacaf1d8bf1.jpg?hash=aNau7UEXcy)
![20131121_182719[1].jpg 20131121_182719[1].jpg](https://www.lincolnvscadillac.com/forum/data/attachments/72/72174-b64d9b889b61030a0a8a59da0f2ccdc0.jpg?hash=tk2biJthAw)
![20131121_192126[1].jpg 20131121_192126[1].jpg](https://www.lincolnvscadillac.com/forum/data/attachments/72/72186-aeb0a0e8757cea38bfb1c8187051ab9c.jpg?hash=rrCg6HV86j)
![20131121_192138[1].jpg 20131121_192138[1].jpg](https://www.lincolnvscadillac.com/forum/data/attachments/72/72187-df41cd7fd6fad21d442ddc499d0eec2c.jpg?hash=30HNf9b60h)
![20131121_192557[1].jpg 20131121_192557[1].jpg](https://www.lincolnvscadillac.com/forum/data/attachments/72/72188-4e032cc19e0d7e65e438953038bc2428.jpg?hash=TgMswZ4Nfm)
View attachment 828463697View attachment 828463698View attachment 828463699View attachment 828463711View attachment 828463712View attachment 828463713
It's gonna be a long holiday weekend for me.....
I will be working on my suspension parts and a new Head unit.
parts:
Motorcraft MCSOE39 Control Arm
Motorcraft MCSOE38 Control Arm
ACDelco 45G0435 Bar Link Stabilizer
ACDelco 45G0434 Bar Link Stabilizer
Moog K500084 Ball Joint (X2)
Moog K80245 Sway Bar Link Kit
Moog K80246 Sway Bar Link Kit
Moog ES800415 Tie Rod End
Moog ES800414 Tie Rod End
Moog K80261 Sway Bar Link Kit (x2)
OEM 25550 Strut Spring Compressor
Metra 95-5000B Double DIN Installation Dash Kit for 2000-2006 Lincoln LS or 2002-2005 Ford T-Bird (Black, Silver)
Kenwood DDX470 Double Din
Still waiting for the rear tie rod link stabilizer by Deeza, currently its out of stock.
Dog is also posing for the picture lol.....![]()
Speaking of suspension work, just got inner tie rods, lower front ball joints, rear wheel bearings, and a serpentine belt for good measure.
Thus concluding my suspension rebuild. Now I can start stock piling those coolant parts to replace this summer.
PMjolinc01 said:Make sure you check the lengths of your inner tie rods. Iirc mine were different lengths on each side.
Replaced the stock front speakers with Pioneer 3-way sounds a little bit better in the afternoon. Last night when I was backing out of the driveway and making a sharp turn "Check Advancetrac" showed in the message center, turned off the car and restarted still there. This morning tried restarting and it's gone. Not sure if this a fluke but could be part of POS engineering on LS electronics. Probably battery related or just too cold.About 16 degrees here in Kansas City
Finally got done with my front and rear end suspension work. I replaced the front tie rods, sway bar links, ball joints (had a shop pulled the old one and pressed in the new one for me $100) upper control arms, installed eibach lowering springs. Replaced rear sway bar links and installed eibach lowering springs, and still waiting for my rear tie rod kit thru the mail.
Now made an appointment for my wheel alignment, the car's front end is out of allignment very bad, drove the car one block and it's eating the tires outside so bad, I might need to have it towed to the wheel allignment shop, about 10 miles away from my house. What yall think?
I once made the mistake of driving about 10 miles to an alignment shop after replacing some front end parts, and wound up replacing a fairly decent set of tires when I got there as a result and I wasn't even that far out on the alignment. If you're eating the tires noticeably within a single block you may not make it to the tire shop.
