Post your mods
1993 Mark VIII
35% Window Tint
Pro-M 85mm MAF
K&N RU3480 Air Filter
Intake silencer/resonators removed
Meziere Electric Water Pump
Custom Intake Tube
Dayco PolyCog Serpentine Belt
Tru-Cool MAX 40,000 GVW rating Transmission Cooler
SCT Performance Chip
Factory 1996 HID Headlamps
Performance Distributors LiveWires - Spark Plug Wires
MotorCraft AWSF-12C Spark Plugs
HyperTech #1011 - 160 degree thermostat
DeMolet DenseCharger Cold Air Intake
1996 EATC(Electronic Air Temperature Control)
Billet Adjustable Fuel Pressure Regulator
Fuel Pressure Gauge
HydroTex MultiFilm 80W-140 HyDiamond Gear Oil
Muscle Products MT-10 Metal Treatment
Walbro 255LPH Fuel Pump
LMS PROPOLY polyurethane carrier bushing kit
Hooker MaximumFlow Mufflers
DynoTech Engineering Metal Matrix Composite Aluminum Driveshaft
PA Performance 4G Cobra 160 Amp Alternator
Odyssey PC1200LMJT Dry Cell Battery
Performance Distributors Screamin' Demon Coil Packs
Steeda UnderDrive Crank Pulley
SCT DynoTune
Kooks 3/4 Length Jet-Hot coated Headers
SCP Solid Motor Mounts
Flaming River Billet Steering Joint
Modified Intake(Radiused/Polished/Coated)
Detroit Truetrac gear type limited slip differential
Motive 4.30 ratio Ring & Pinion
Rear Torsion Brace
Front subframe Bracing
Rear Strut Tower Brace w/ integral amplifier shelf
Ford Racing Performance Parts 30# injectors
Blue Oval Chips Stage III 3800 stall Converter
Custom 2-1/2" SS dual exhaust setup w/ Electric Cutouts
Custom Rear Subframe Bracing
ASHAM8 air suspension adjustment module
SCP Short Rear Sway Bar Link Kit w/ Polyurethane Bushings
Koni Rear Shocks and new improved shock mounts
Addco 1-1/4" Rear Anti-Sway Bar
Fox Lake Ported Heads
Custom Bullet Cams
DirtyDog Performance 4R70W Transmission
Delrin IRS bushings by DLF
Mustang Hub swapped
Cobra brakes w/ Baer Decelarotors
18x9 Chrome FR500 wheels w/ Lincoln Centercaps
255/45-18 Nitto Extreme Performance NT555 tires
4 RockFord Fosgate HPC 2268 6x8 coaxial speakers - 150 watt
Alpine CDA9847 AM/FM/CD/MP3/IPOD Receiver - 50W x 4
Elemental Design 13Ov.2 Subwoofer - 12" - 1200 watt/2 ohm
Elemental Design NINe.1 Class D Amplifier(900 x 1 @ 2 Ohm)
Alpine MRPF240 4 channel Amplifier - 50W x 4
13.11 @ 104.3
306 RWHP 313 RWTQ
1996 Mark VIII
Limo tint
SCT chip
Cobra exhaust manifolds
Dual 2-1/2" Single-X Exhaust
SS Magnaflow mufflers
J-mod/Tranny cooler
Cobra front brakes
18" Bullit wheels
Polyurethane carrier bushing kit
LPW Differential Cover Girdle
4.10 ratio Ring & Pinion
FRPP Traction-lok w/ extra clutch mod
PI Performance 3500 stall triple-disc Torque Converter
Sony AM/FM/CD/MP3 headunit
4 Infiniti Kappa speakers and an Infiniti amp
Two Audiobahn 10inch Subwoofers 900watt RMS each
HCT2200 Audiobahn amp
1 Farad Audiobahn capacitor
14.26 @ 94.6
1996 LSC
window tint
custom exhaust
air silencer delete
air box mod with K&N air filter
4.10 ring and pinion
trac-loc with clutch mod
18 inch wheels with 275 35 R18 tires
coil conversion
H&R lowering springs
HID hi/lo beam conversion
custom made grill
Dirty Dog valve body
Pioneer AVIC-D3
Alpine Type R 6.5s
Alpine Type R 6x8 components x2
custom USB port
320 gig hard drive
2 Alpine Type R 15's
Rockford Fosgate Punch 125.2
Rockford Fosgate Punch 50.1 x2
Optima Red Top battery front
Kenetik battery rear
Viper auto start
Chrome Big Foot gas pedal ;)
Lincoln Cobra Star emblems :D
Lincoln Cobra Star key chain :eek:
98 LSC
tune
spider valve v1 with bigger vent valve
my custom twin compressor setup
rays switch
clif designs 6.5 front component speaker set
blown blaupnkt was for rear fill, just disconnected now
pioneer HU
2 pioneer 10's
2 old as hell, late 80's MTX amps
same era 2 channel MTX crossover
cobrastars
18 inch saleen speedstar replicas
and uhhhhhhh something around 170k (car is under snow and i aint diggin it out)
98 Mark VIII base/LSC, LSC grille and other body parts,20inch akuza creepin wheels,5%tint,LMS chip,fuel pressure regulator,900 cfm mass air kit (LMS) K&N filter,trans cooler,magnaflow true dual exhuast,ford racing plugs and wires, (NOT INSTALLED YET) cobra brakes,3:73 ford racing gears with LSD,2 JL audio w 7 woofers with 2 1,000 watt JL amps,vogue tires,all new carpet and headliner, and a dyno tune
I've noticed a lot of you have adjustable fuel pressure regulator on your stock engines w/ bolt-ons. Why?
I have found you can tune the car at the track with a slight change in the FPR.
My 93- Everthing is still stock to this day. Including the bags. Sorry it's had a tune-up.
The chamelion- paint code TA factory.-Everything is original, even the plugs and wires for now. The fuel pump has been replaced, and it has a napa reman starter [weird huh?]. That is all I can tell from the list of invoices I got with the car.
And the 95- Trans-go shift kit. 3 inch center pipe. No cats. Flo's for teh sound of it. And a dacco 2500 stall converter. Other things to come this thaw.
Sorry I was busy for the last few days but here is the list of mods that I had last year.
Best time to date on this old setup was 10.64@128 mph
ENGINE:
Forged bottom end with:
Cobra Crank
Manley rods with ARP 2000 bolts
Manley Flat top Pistons (0.020 over)
SHM Piston rings.
Rotating assembly was balanced and prepared by Seanhylandmotorsports and the Engine was reassembled by ME.
Stock heads ported by Me to match IMRC deletes.
Cobra Intake manifold( Ported by me and runners were shortened 2 inches)
POWER ADDER:
Vortech V2 S trim running 12 PSI of boost.(3.2 Reichard racing 6 rib Pulley)
Anderson Meth Injection.
Upgraded Bypass Valve.
Reichard racing Manual belt tensioner and steel cobra tensioner help keeping the belt tight.
FUEL:
42 Injectors
255 Walbro HP fuel Pump.
Exhaust:
Kooks Headers from SCP.
Dual 2.5 inch into single 3.5 inch pipe and 3.5 inch Dynomax straight through muffler.
Trans:
Stock and original Trans with 94k miles on it with J Mod.
Dirtydog 4200 stall Torque Converter.
2 trans coolers.
trans temp gauge.
Rear end ,suspension:
Stock rear end with 4.10 gears and track lock.
03 cobra coupe rear shocks.
KYB front shocks.
Coil over conversion and lowered over 2 inches.
Front sway bar removed.
Hub swapped to 4.5" bolt pattern.
Weld Prostar Wheels.
MMX driveshaft.
Bolt ons or supporting mods.
80mm C&L MAF
Meziere Electric water pump.
BBK 65mm Throttle body.
And a Driver mod:D
New mods coming soon.:nxsmile
OK, this is mostly from memory so I am probably going to forget stuff, but let's see...
Basic "every" Mark VIII mods:
1-2 accumulator
Mercon V in the tranny
Door handles replaced (going to have to happen again on the driver's side because some f*cker tried to break into my car at the movie theater)
Black paint with all chrome deleted painted sh*tastically by yours truly
New antenna motor
WD-40'd the crap out of the door latch
Lots of fiddly bit parts from other dead Mark VIIIs
Before I owned it, some previous owner replaced a good amount of the air ride with new components
Performance mods:
180 degree T-stat
March underdrive pulleys
Screamin' Demon coil packs
Livewires
NGK TR6 plugs
3.73 gear set with Trak-lock
Intake tube cleaned up, silencers removed
Airbox restrictions removed
Magnaflow catback exhaust
Twin 3" cutouts just aft of the manifolds
3200 RPM stall converter
Snow Performance Water/Meth injection
NX 20122 nitrous "wet" kit with 0-150 shot, electronically variable
NOS nitrous purge kit
Electronics mods
In dash VR3 VD640G GPS/CD/DVD/iPod unit
Dynotune A/F meter
Dynotune progressive nitrous controller
Snow Performance vacuum based water/meth controller
Hobbes low fuel pressure nitrous cutout switch
Custom built and installed nitrous/water meth controller and indicator system (hard to explain this one, you'd just have to see it)
SCT 4 bank flip chip, custom tuned
And then usually when I am at the track I am running on BFG 255/50/16 drag radials. Gotta get some new ones, though.
Best motor time is a 13.9 and best nitrous time is a 12.1. It has more in it, as last year I was posting consistent 12.3 times on street tires. Local track is at 1600 feet but the D/A here is always usually in the 2500 range.
97 Pewter Gray Base
K&N panel filter
diseboweled cats
Magnaflow resonator X pipe (in place of 3rd cat)
Magnaflow mufflers
SCT tune
Redline tuning billet hood struts
1993 Mark VIII
35% Window Tint
Pro-M 85mm MAF
K&N RU3480 Air Filter...
When I first started reading that I didn't look at the name, I just started to think to myself "Man, this guy could compete with Driller!" :) That list is just all kinds of impressive.
One thing I DO have that seems to be unique is some specific data about track results:
1/4 mile ET: 12.1891
1/4 mile MPH: 109.57
Track Altitude: 1330 feet
Temperature: 65 degrees
Humidity: 81%
Pressure: 30.15"
That gives me a corrected altitude of 1850 feet.
Corrected 1/4 mile ET: 11.933
Corrected 1/4 mile MPH: 111.981
93 one piece drive shaft
Cobra 13" brakes
98 cobra intake
3 piece under drive pully kit
blue oval chips j-mod valve body
3.73 gears
ford racing trak lok
flowmaster mufflers
3rd cat delete, replace with xpipe
tranny cooler
K&N panel filter
basic off of the top of my head
forged motor
kenne bell 2.2
alcohol injections dual nozzle stage 2 meth kit
3200 Stahl billet converter
BC auto stage 4 tranny
custom drive shaft
3.55 w/ trac lock
hub swap
18x9-18x10 Boyd coddington smoothie II's with 275/35 & 295/35
cobra brakes
custom paint
custom hood
auto meter boost, trans temp, and fuel pressure gauges
alpine iva-d310
infinity kappa 6x8 components f&r
3-10" mtx 7000's
Harrison labs 1000 watt sub amp and campasitor
alpine pdx 4.150 amp
along with the do dads and crap to make it all work
coil spring conversion
intake tube silencers removed
k&n cone filter
magna flow x pipe
2.5 dual exhaust
JL audio 1000/1
JL 12w7
and
410s on the way
I figured we would start a post your mods thread. If you don't have any performance mods post your appearance or sound system mods.
Here's Mine:
PREVIOUS best track time on nitrous setup:
11.7 @ 119mph Nitrous
13.2 @ 106mph NA
Never ran the Kenne Bell setup at the track. Though it did dyno 492whp & 507wtq on 15psi.
LATEST SETUP:
1994 Lincoln Mark VIII
- 4.6 DOHC b series heads
- 96-98 Cobra Cams (degree'd)
- Ported Cobra Intake w/ modified runners
- Built 4.6 DOHC (Manley Rods, Probe Pistons, Cobra Crank, ARP Everything)
- Vortech V1 Supercharger Kit
- Procharger BIG RED BOV
- Custom Powerpipe
- Snow Performance stage 2 Methanol Injection
- Innovators West 18% overdrive pulley
- 8-rib Conversion
- Accufab sigle blade TB
- MMR IMRC Deletes
- Meziere Electric Water Pump
- 90mm MAF (lightning MAF)
- Kooks Headers w/ 3" collectors
- Custom 3" pipes from collectors y-piped into the 3.5" cutout
- 3.5" Electric cutout
- Custom Twin 255lpm fuel pumps
- 60lb Injectors
- Kenne Bell Boost a Spark
- MSD wires
- MSD Coil Pack
- Deleted Emissions crap
- 180* Thermostat
- Mild Built 4r70w Tranny w/ a TransGo Shift kit
- Edge 3000 stall
- Tranny Cooler
- 3.73 gears w/ posi
- 1 piece Driveshaft
- 1.5" Lowered Coil Conversion suspension kit
- MickeyThompson 315/45R16 (Race tires)
- Nitto 555R 245/50R16 (street tires)
- SCT custom tuning
- LC1 Wideband w/ gauge
- Autometer Boost gauge
- Raptor Shift Light
- 30% Tint
Should be 600whp range.
really like this setup, whats a rough pricetag on all that stuff?
1-2 accumulator
New antenna motor
Performance mods:
180 degree T-stat
Livewires
NGK TR6 plugs
Electronics mods
Dynotune A/F meter
nice times! what high stall do you have? I'm losing time in the beginning - but no wheel spin. best 60 foot is like 2.1. but its a turd out of the hole. I have a 2002 stang trans and sct chip, the shifts are still not as fast as i'de like them to be, losing time there.
And it seems when it pops into third that its a huge turd also dipping below the peak HP band.
I think if i had these things corrected it would be a low 14 sec car and a high 13 like yours if i did some weight reduction.
a buddy of mine whos like a jockey ran my car and ran the exact same time.
i got about 20 passes with the same time. 14.6 @ 95, i put some crappier tires on and the times when up to 14.9 @ 92. They are taller 225/75/16, but i got them for a steal and there a good touring tire, i like lonnng drives in the country!
I also run dynotune stuff, Dan is the MAN! I just grabbed an Innovate G2 for my Corrado - got an LC-1 on there, all autometer analog stuff.
If you hook up an lc-1 to the markviii - how does that tie into the sct software and where did you put the bosche wideband 02? did you leave in the stock 02s?
My rado was easy it only has one 02 and that happends to be the same bosche one the LC-1 uses ( i replaced it to have a clean o2).
My SCT chip was tuned on the dyno on and off spray so i didn't factor an lc-1 into the equation for the mark i'm very confident in my tuner: -
http://www.youtube.com/watch?v=hKCTwRtF5Lk
hey medium D, what bulb size did you go for in your aftermarket HID in LSC housings?
