Sapperfire
You good sir are a fu*king retard..........:shifty:
i think that guy just thought of some crazy sh!t to say in a random thread..none of that made ANY sence what so ever
2 words GREAT STUFFYou did WHAT?!?
supposedly the moogs splitwhat is so important about using the factory srb? I was looking at rock auto's site which list moogs and they state that they are the improved design on one and the problem solver design on the other.
And you...sir, are a fu€king moron. I love how people feel obliged to try and cut others down with stupid little remarks from the comfort of their computer.
Your parents ever tell you the rule about having nothing nice to say?
Go ahead and give them a try, if you'd like. But, in my experience, they're junk.
replaced the uppers on the 95 to get to the driver side rear control nut i cut an access hole removed and replaced the nut. cut a 2x3 in hole then painted it and used metal tape to hold it in place. then replaced the plastic inner liner of the fender. much quicker then fighting the master cylinder and all the congestion above it. if you cut becareful how deep you go on the cut .
So your saying that its fine to cut out part of the shock tower to get to a bolt when you can get to it just fine the right way??? Thats the stupidest thing ive ever heard and yes if i met him in person id tell him the same damn thing!! Hacking up a car just to make it "easyer" to replace a part is lazy and retarded, people like that need to be kicked in the balls and then have there cars and tools taken from them so they never do it again.
Speaking of which kstills, I had to cut the exact same hole as jds353 to fit my clutch master cylinder. I must be a fuc/ ing idiot as well.
Oh noes!!!!
Let's see..... you have called me a f@ckin retard.You good sir are a fu*king retard..........:shifty:
All I can say about the moog srb is they are even worse when you try and use the fronts in the back![]()
Oh noes!!!!
+1 call Max get OEM
fyi,
jds353 was racing and building cars while you were still a twinkle in your daddy's eye (judging by your maturity level anyway)
You had every right to call me a f@ckin retard and never did.
:slap:
Following your logic, it would be stupid of me to cut my K1500's control arm bolts out when trying to replace the bushings. Nevermind that it's a rust belt truck, and the underpinnings are close to rounded off by corrosion.
Yawn....
i did call max today...the parts guy at the ford dealership that we use thru the shop isn't very good. I was asking questions about the srbings cause i need to rebuild my front end. My ford guy said 130/side for the srb kit. After i called max, i was told i could just order the rubbers for something like 60 which makes more sense since moogs are 40 or so. I will buy oem when possible, but $90/side over moog for rubber bushings is a little excessive without justification.
