ajv8
water in the covers is cowl related i think. only happens on the v6
			I probably just bought a bad engine but I way to make absolutely sure it's something not easy to fix.The car is getting water in the crank case when I put the garden hose into the coolant intake hose that goes into the top of the intake manifold so it's not the heater core I put the hose on the heater core port and I have water coming from both heater core ports so it's definitely internal I am gonna pull the lower intake manifold tomorrow and see if I can Isolate my overheating issue because it seems the hoses are all flowing properly.
I would rather it be a gasket than a crack in the block but as water passages go its probably a crack somewhere below the lower intake.I really should proof read these posts before I send them. I have to make absolutely sure it's not worth fixing.
Second thing is when I pressure tested the cooling system by hooking the garden hose to the overflow outlet tube on the bottom of the degas bottle I got water coming out of my oil pan
A cracked block is not an easy fix. It's junk.I probably just bought a bad engine but I way to make absolutely sure it's something not easy to fix.
Great way to kill the cooling system. It can't begin to handle the pressure a water hose supplies..... I pressure tested the cooling system by hooking the garden hose to the overflow outlet tube on the bottom of the degas bottle ...
Yes it's the same motor but I am speculating on where the water that is mixing with my oil is coming from. I put the bars leak in it and I don't think it fixed anything but I am also losing a lot of coolant so I am on a mission to find out where it is going.This IS the same engine that has the cracked block , (and bars leak) correct?
And you are wondering why you are getting water out of the oil pan???
There is your answer... again.A cracked block is not an easy fix. It's junk.
Where do you think the coolant goes... when the block is cracked???but I am also losing a lot of coolant so I am on a mission to find out where it is going.
I don't have much else going on so I guess you could say I'm working my way up to pulling the engine back out. I just wanted to test the lines and see where all that bars leak went if it didn't seal my coolant leak.Where do you think the coolant goes... when the block is cracked???
The formula that I bought said head gasket sealer but you are right when you are dealing with an aluminum block there isn't any gaurentee it's gonna seal it up.Bars Leak is for radiators... NOT for engine blocks. Especially aluminum engine blocks. I can think of about 3 other "block sealers" that would work better... but none of them will fix what you are dealing with.
No offense meant... but you are in over your head at this point.
Yes I'm wasting time that could be better spent disassembling the parts that have to come off to pull the motor I have the intake manifold off so that's one piece out of the wayWaste of time and energy... that could be applied to installing another engine.
Right now you have a pile of scrap between the front wheels... unless you are a master TIG welder. Even then you won't be able to weld any internal cracks.
You are wasting your time... but what do I know???![]()
Wasting time and you have probably ruined your DCCV, and maybe the heater cores with that stuff.Yes I'm wasting time that could be better spent disassembling the parts that have to come off to pull the motor I have the intake manifold off so that's one piece out of the way
