rayner601
I traded the 97 Mark for a 09 4x4 king ranch
First tow yesterday ( most likely fuel pump)after driving 3 different 8s for 11 years and 300,000 miles. By obsolete I do not mean unrealiable. It is things like rear light assy. no work! Rear sway bar rusted through. If anyone hits me hard the car is gone due to replacement parts. Everything is probably availeablt through this site and major searches ( closest sway bar 3 hr drive ) But with 4 kids 2 in college and a crazy chedule not alot of time to search and retreive things for a car I need every day. There is no bigger fan of these cars than me I drove to Maryland from N.Y. to but the last 96 with 40k on it. Maybe it is the 97 coasmetic rarities that are my problem. sorry for rambling!
actually the booster wasa pain when i did it, but not as bad as the valve cover. it does come out like the dealer mechanic said when you put it in spin it and it clears that little triangle on valve cover. man i cursedand threw things for hours before i got the trick. i was going to take off the valve cover to put the booster on, but then i remembered fromdoing valve cover you cant put it on with booster on.
Use flex primer for plastics??
Put an electric water pump in!
gonna order this tonight for my mark: in red to match the front
http://www.ebay.com/itm/1993-96-Lin...Parts_Accessories&vxp=mtr&hash=item2c6440277d
Boredom at its finest
Booster out in 2 minutes
Pictures!
I've got a Meziere that I bought like 6 months ago waiting to go in.
i believe geno has the cobrastar emblems for that, if you click on his onebadmk8 name it should route you there
I don't think mine has any bolts. I bought it slightly used? You can't use the stock bolts?
