I need to rent one of those so bad. They are about $80 to rent but also need a $200 deposit.
Where would you rent one of those? Since I put Jamie's Speedstars on, the damn things rub. I have to leave the air ride switch off just to drive it.
You have higher rate springs. Duh.i dont get this rich, you have the same exact car as me, mine is lower than yours, the wheels were on my car and all they did was go from mine to yours, and they rub on yours???? i cannot see how unless you have 800lbs of sand bags in your trunk, even hitting dips in my car the tires never even made contact with the body. you got something going on, either the back of your car is still leaking air, or your rear height sensor is screwed. or you are jumping the car like the duke boys.
So what temp did you heat the paint to before you started rolling?
not hot enough![]()
And how much was that? I was told to do it to 140* but on the white one I still got a couple small cracks. Then again it wad 50* when I did it and the metal was cooling very fast. I even bought a laser temp gun just for that occasion.not hot enough![]()
Consider it practice for mine.
