It will lock up by itself, if you use the '2' polition, but depending on conditions. 'cause you can use engine braking in the '2', I'm pretty shure, it sometimes locks up.
Hmmm, mine doesn't seem to lock up when manually shifted into 2nd gear.
Looks like I need to find the wire that energizes the torque converter lock up function and hook it up to a toggle switch. This would eliminate slippage which creates heat.
The trans will take care of shifting all on its own. Don't :q:q:q:q with it. The trans works the way it is supposed to, if you were supposed to manually control tc lock up, the car would have come with a button from the factory. The slime thing was bad enough, i think you need to set the tools down before you tear up a perfectly good mark...
No, this stupid fock wants to tow a 4x4 pickup over 1500 miles with his Mark VIII.If it`s a small utility trailer, I don`t really see any problems.
Well,......other than looking silly.
BUY A TRUCK!!!!!!
or you can do the OTHER solution when you want to command certain gears, put a MANUAL transmission in it.............otherwise just FU(K your car up
if i ever see some idiot towing something with a Mark8, i think ill have to do a pit manuever...especially if its heading towards Texas
Which wire? So to you the TC is just some big solinoid? Couldnt possible be a function of load, pressure, RPM, trans temp and car speed? Couldnt be a function precisly controlled by the computer? Its just on and off right?Does anyone know which wire controls the lock up?
