BAD97LSC
bill i just got a 97 lsc yesterday, i drove it back to my shop and parked it, i havent been under it yet but i'm sure i can help you with the cans , you dont need the evap tray correct?
cut the :q:q:q:qer apart
That is a beautiful car and the color I wanted the most but yeah, I need the cans in the tray. :lol: Don't need the tray itself though. I was gonna help another member on here out that needed one though if I did happen to get a tray.cut the :q:q:q:qer apart
 Tilted the tank down and saw I neglected to properly seat the hose which would explain why the plastic lock gave me so much trouble. :lol:
I wish you had sold it to me...
Good deal Laser!
Yay it's finally alive and my first blower install ;-) kinda
now I go sleepy time
Now you need to come home to Houston and do one on my 93.
 I couuld tell right away there was no spark.
 I couuld tell right away there was no spark.  After futzin around a bit I discovered the crank angle sensor is bad. Guess when the engine heats up it causes the sensors magnet to stick. I have another but not sure how I am gonna replace it. The front most bolt on the AC compressor is now completly blocked by the sway bar. Can only back it out 1/8" and that just aint enough. Oh well, I will figure it out somehow.
 After futzin around a bit I discovered the crank angle sensor is bad. Guess when the engine heats up it causes the sensors magnet to stick. I have another but not sure how I am gonna replace it. The front most bolt on the AC compressor is now completly blocked by the sway bar. Can only back it out 1/8" and that just aint enough. Oh well, I will figure it out somehow.How bout you bring the car to my shop "Laser and Sapperfire's git er done garage" with all the hardware and a couple grand and we can "Git er done!"
The drawing for the free motor install was won by Laser...it doesn't matter that his was the only name in the hat
