Green Machine
The radio comes out in about 20 seconds with the little u-shaped tools they sell for about $5.
I made my radio removal tool out of 1 metal wire coathanger and pair of side cutters.
Typical lead acid car battery had apx 70 amp storage capacity. The stock JBL amp will pull around 3 amps when in idle mode. All it would take is 20 hours before the battery would be too weak to start the car. I have never seen a Marks amp do it but I have seen several other OEM amps fail in the stuck on position.
You need to measure the parasitic drain and then diagnose it from there by either removing fuses one by one or other means. Once you know the circuit, you can start disconnecting components from it to further narrow it down. Hopefully you'll find it doing that or you'll be chasing wires next
Google 'how to find parasitic draw on battery' to see how to do it, remember to unplug under hood bulbs and interior ones if anythings open etc...
BTW, do you know what 850 CCA stands for?
I think the fuses for the seats needs to be removed and for the stereo and amp. Then see if it dies again.
Google can be your friend... look for fuse locations yourself.
my muffler bearing belt snapped and flew and broke my halogen fluid tank the other day. now the car wont shift into second.....:![]()
I tried looking for wiring diagrams as well as fuse panel diagrams but I can only find them for Gen 1's
Pretty sure I have an owners manual from my 97 Evergreen LSC sitting around here somewhere. Wanna buy it?
$1,000,000
