fastmark1993
could you not triple post? ;D
Jeasus Christ Francis, lighten the fock up! I thought you were someone who could take a little jab when they said something really stupid and take it in stride. I fock up all the time, someone jabs and I laugh and correct myself. I aint an internet tough guy, im just a guy. Wanna engauge in fisticuffs then PM me and ill give you directions but that was not my intent.You sure like to run your mouth or fingers. Have you ever heard the phrase, "If you don't have something nice to say, shut your :q:q:q:qing mouth? I was in a rush this morning and :q:q:q:qed up one sentence. So sue me. Call me old fashioned but these days its real easy to hide behind a computer and talk :q:q:q:q. Does putting someone down make you feel good? Its that kind of attitude that makes people not want to help anyone.
So here is the error in your reply. The fires are caused because of an electrical fault in the switch and the wire melting and setting the brake fluid on fire. If there is no power because the battery is disconnected then how is that wire gonna short out and melt and catch on fire?
you tell me!
If your going to post here....grow your skin a little thicker.Butt don't hurt. Sick of :q:q:q:q talkers.
Could be but doubtful.Master cylinder going bad?
Nope.Could it be a sticking caliper?
Ok thanks man....I just have no idea, as you can tellno fordnut yours was leaking thats the new style switch and the adapter harness to fit it (better cuz you got rid of the leaking switch) thats how i did mine cuz it was :shifty: leaking :shifty: ill get a pic of the double fused gizmo when the wife gets home, thats whats on the explorer
Yep looked everywere after gmans car burnt I was taking no chances.Have you checked for any leaks under the master cylinder.
I had air just not real cold it was cycling so You could tell it was low.Also, if you had no air, that should have meant that your compressor wasn't turning. No 134a means no compressor turn, unless it's just low and then it usually will come on and go off, over and over. Make sure belt is up to snuff too.
When you added some 134a, that made the compressor kick on and get hotter than it's used to being if it hasn't been on in a while. Something could have been on it that burned off or the freon leak itself could be coming inside the cabin with you. On a muggy night, start the car outside, turn the air on Max AC and see if your windows start to fog up within 10 or 15 min.
It will get done, I thought it was until this whole brake crap came up.As for the cruise issue, Kirk, take your car there quick. I have taken the 93, 94 & 95 and had all three done. I took them personally. Guess what? I still get letters in the mail saying that they haven't been done. 93, 94, 95 and I know they have. I watched them do the work. I didn't actually see the 93 because it was a bitch and had to be taken in the back but the 94 and 95 was done right there in the roll through of the shop. Please check for brake fluid leaks all around that master cylinder. Even though my fire is not related to any of this, I'm giving you a reminder pic.![]()
Yessssir.
We been back and forth already today, talking about tis and tat.
You knows.
