ripped camel
So many of you know and have been incessantly trying to help me figure out this vibration issue. The problem is above 70mph the car starts to vibrate so violently that the dashboard, rear view, and everything shakes a good 1/2" up and down. It tends to get worse when I am going that fast and let off the gas. So accelerating hard above 70mph makes it shake and then letting off makes it even worse. Once under 70mph the vibration is gone.
1. Originally Ford Nut thought it was the driveshaft, which I'm starting to think maybe that really is the problem.
2. After Ford Nut came up with that idea I took the car to the shop and they said I have broken motor mounts. Problem is if it's the motor mounts causing the vibration I speak of wouldn't the vibration be consistent and not just above 70mph?
3. The shop then said motor mounts wouldn't cause vibration over 70mph and blamed it on my bad tires. So I bought new tires. Vibration is till there no change after the tires.
So now when looking at aftermarket driveshafts it mentions that there is a strong vibration when you get gears. I wonder if I'm getting that same vibration without gears and it is my driveshaft.
Could my new exhaust setup be heating up my driveshaft warping it?
What do you guys think? The person with the biggest spoon is the only person that gets to claim they spoonfed me!
