Quik LS
Does anyone know how much it would cost to modify the stock hood? Just a ballpark guess, since weight savings wont be much.
to do what - cut a hole in it so the shaker (which sits on the engine cover) pokes through?
I'm good with my stock hood. Thanks.
On the Heat Extractor hoods. They are great hood and very cool, but do not get them if you want to keep it clean under the hood if you car sits outside alot. I had a 94 Saleen that was my wifes daily driver, it was impossible to keep the engine bay clean, water will run down into the engine, if it sits under a tree, leaves will fall into the openings. Just wanted to inform anyone that was thinking about the extractor hoods as far if it is better suited for the conditions of your car and your use of it.
Don't want water running into the engine.....think coils.
I was just thinking.. Could you make a tube from each one and send the air directly to the air filter? Then you could put a K&N DryCharger on there to protect yourself from the water.. Then you could make some kind of thing that seals the air filter and rest of the engine that separates when you lift the hood. Just a thought..
Well I was thinking of getting the hood modified like wildstang607 did. I don't really like the whole shaker ram-air system running to the stock airbox. Just seems like it's putting more twists & turns in the intake than it should IMO.to do what - cut a hole in it so the shaker (which sits on the engine cover) pokes through?
if you customize the mustang setup - it is kinda functional...
I'm sure it would look nice on a gen 2 also.
650-800 is alot to spend on an unproven system, but that would look f&*ckin sweet strap to the top of a gen one engine
unproven? it doesn't look that complicated to add to any car....
...the stock piping layout of the two gens would take over and make it all better
You going to cut a hole in your hood?
