when looking at the imrcs after 4k what will I see?.
easist way is to verify they are moving when the engine is started, that way your not "revving the crap" out of the motor.
when the engine is off.. the IMRCs are OPEN
when you start it, vacuum supplied to the soleniods snap the IMRC's closed.
See my post in this thread about "where to look".
Or you could supply vacuum {engine off} with a vacuum pump TO the IMRC soleniods and with the engine off..
you should be able to hear the IMRC open and close if the engine is off.
You can also visually verify the IMRC "shafts" are turning at the same time.
check the vacuum T on the drivers side on the rear of the intake manifold "it's hard to see".
That Vacuum T often gets a pin hole or larger leak in it and wreaks havoc with proper IMRC operation.
