Can anyone guess?
94m5
Dmaup's Daddy
Colorado Springs, CO
What this is/will be?
Bottom of an engine block?
...Or, rather, bottom and rear section (where starter would bolt) Yup, im sure thats it.
Jaime gets the cookie...............
It's a model I'm building off of a Teksid block I have sitting on my apartment floor as we speak.
There is ALOT more to this project than I'm wanting to talk about right now, but I'll let ya follow along with the progress.
Here is a rendering of what it looks like right now.
Mike
Impressive...
I've been learning Solidworks for work. A lot more involved than initial impression.
you had better get this kenne bell open house in there before i get it put on I'm getting antsy and your gunna run out of time
Here is is Now.
I'm hoping to have the Block done mid week, then I gotta get the cylinder heads done.
Jeb, What I really need is that Cobra Intake.................
After 10 hours........... I'm done for the night.
If you can't tell, I'm doing everything correctly on this. Oil passages, Coolant galleries, All a that stuff.
Some of you may hate the thought, but If i don't like the way the model is turning out, I'm gonna take this Block to work, and Section it so I can get measurments inside.
Hope you like the progress sofar.
Mike
My question is, after you get it all drawn up, how much is it going to cost to have the block and everything cast or machined???
That would probably cost ALOT.
This is only gonna be used for deminsional accuracy of a sheet metal intake I'm working on.
Ok, I have most of the right deck surface completed. Head Bolt casting bosses and holes as well.
Now I have to get all of the water passages from the water pump to the block galley done. You'll notice it starts getting cluttered about now.
Drivers Side cylinder bank is done, and have started to detail the valley between the Cylinder banks.
I'm too friggin tired to do any more with it tonight.
Mike
Terminator top end, with B heads.
Ford Nut.... No I'm not, eventually I'll be good enough to compete but not right now.
Mike
I was wondering why you were doing this. Makes sense. Let me know if you are making more than one! :)
Mike
:confused:
http://www.imts.com/
IMTS 2008 is the 27th edition of the premier manufacturing technology show in North America. More than 1,500 exhibiting companies will occupy 1.2 million net square feet of exhibit space at the McCormick Place complex in Chicago, Illinois. IMTS is held every even-numbered year in Chicago and attracts more than 91,000 buyers and sellers from 119 countries.
How do you compete ? fork truck races ? :D
I will be there Sept 9 - 10. I love the windy city.
Sorry man.
was a long night last night. I got confused with another thread on a different forum.
I may very well be there.
Mike
Ok,
It may not look like much has happened, but as it gets more detailed it takes more work to get the sketches right, and then you have to go back through and clean up what was'nt right.
anywho.......... I should be starting on the casing walls and oil drain back holes pretty soon.
Mike
....I'm getting a headache just looking at this!
Very good work, on a side note....shiny....object.....haha
