Spree
Now I can't wait to get my forward bushings off so I can see how squished THEY are compared to new! Were yours noisy or causing oscillations/NVH thru the steering?
Nothing...mine made no noise or vibration's but had a slight pull to the left (very slight) when applying the brakes, still drove perfectly straight, but there was a noise when slowing down (not sure how to describe it), but when I sprayed PB blaster on the LCA ball joint, the noise would go away for a week or so. From what everyone was saying...it sounded like the LCA,s or the SRB's so I thought I would change both. Waaay to many miles on these!
Was just checking out the ball joint for the first time tonight and there was just a little play and it wasn't smooth when turning it (not smooth at all)! It was defiantly bad (but would have probably lasted longer). The SRB's through the LCA's were bad...bad causing a clunk when turning all the way right or all the way left (still would have lasted longer).
I'm convinced that if there is no play in your forward bushing's, (like mine had....no play), then there still good, but I thought I would change everything anyway (since I bought them in advance).
If you change your FRW SRB's, make some spacer's like I did....they fit like a glove!! These spacer's are SWEET!
Thank's to DLF and slowmkvii in post 1.
If I had to make the spacer's again I would make them with 1.250 end cap's, this would only take me a couple minute's out of the tube I already have. I'm going to make a few set's this week just to play around around with the CNC some more.
