Bumping an old thread but just wanted to say thank you for the part numbers and good info in this thread....My LS started having overheating issues and I was told a by a shop that it had the "Blown head gasket, pretty much needs a new engine" speech because they had bled the system multiple times and it was still taking in air, but they couldn't find a leak anywhere.
Had the coolant checked for contamination, zero. No white smoke from exhaust either. Car begins to run hot and fans kick on high but if I put the heat on the temp comes right down...
Now maybe you guys can help with this but here's what was replaced...in order to trips to the shop and the result
-First, brought the car to the shop because it was running hot. I had checked the degas bottle, noticed it was low on coolant and I hadn't flushed the coolant since owning the car for three years so I figured, time for a flush and see if the system holds pressure. System did fine on the pressure test. Small leak coming from the bottom hose of the degas bottle. The degas bottle was replaced due to stress cracks being present (I figured why not as they are known to crack, however, the cap was not replaced, didn't know these were separate parts), coolant was flushed and changed. Off I went...
Result: car wouldn't heat up at all, never got off the C mark, even with 30 minutes of driving
-Called the shop, stated it seemed like the Thermostat was stuck open as the car wasn't heating up at all, explained what was going on. Brought it in, they determined the thermostat needed replacing because "there was a hole in it" (on the invoice they replaced the thermostat housing, not the thermostat....) System was bled again, off I went...
Result: Rad fans began to run on high after 10 minutes of driving and would stay on. Temp gauge sat just a tad over its normal position.
Called the shop, explained problems with the fans. Brought it in. They bled the system again, stated they removed the thermostat and housing, reinstalled, stated they replaced the thermostat with a new unit thinking it was faulty. Car still overheated. Bled the system again, stated it kept getting air in the system--Result with them ---> "Sir you have a blown head gasket..."
Currently: Car overheats (needle sits a little higher than normal, not on the H mark or anything), fans run on high. If I put the heat on full blast at 90*, temp drops right back down.
My thoughts after reading this forum is there is is/are cracks in the cooling system and thats causing the overheating issue. Car has 87k miles on it.
Just put my shopping cart together on Tasca...curious to hear your thoughts
