Telco
SIA called, said the trans control solenoids were shot. Replaced all, dropping it back in the mail today. 168 bucks and some change.
I hear you. For my McLaren Grill I bought some blackout tape and used a paper hole punch to create some black circles of blackout tape. Then applied them where the tabs are.
With the lighter color LS I also put blackout tape behind the grill on the supports behind the grill so the lighter color of the car would not show through.View attachment 828472144
It solved the issue with the tabs showing through on the grill.
Maybe the FETs that control the solenoids? (No solenoids in the PCM.)
Hi!
Brake pads / brake fluid / oil / oil filter / oil pan gasket.
LED interior conversion.
HU from oem to pioneer.
Swapping seats. driver seat is on repairing
The carpet is waiting.
regards!
first cloth LS i've ever seen
Full LED conversion
Fixed my driver side window track (3 broken tabs, but glass did not fall in)
View attachment 828472105View attachment 828472106View attachment 828472107View attachment 828472108
How did you release the door lock cable? the section in the door or from the lock itself. Just did my first one and was fighting with that for a bit. ended up just leaving it connected and fishing the new regulator in since I couldn't get that cable to release at all.
