Finished replacing the solenoid and it did not correct my problem. 1-2, 2-3 and 3-4 shifts are very hard, bangs into gear almost like it has a shift kit except it also does it at just off idle acceleration. Almost every shift is a kick in the pants, occasionally it will shift properly and when it does it's always a surprise. It also takes two tries to actually get into third gear. Run it easy or hard, and the shift goes one, two, three-two-three, four, five. No codes are set, and the new solenoid is a new Ford part with assumed all updates included. Any ideas?
Pcm or fluid level.
