I found this in an old hardware store, made by DAP. Glued the lens on then ran a 1/2" bead sealing the lense to the housing. Are you talking about Gen 1? Cut or cooked off the lens?
Gen 1 LSC Housings.
I used a heat gun to take them apart. I glued the lenses back together with GOOP as suggested by members on here. It says adhesive and sealant. If that's good enough then I'm fine, I just wanted to be sure. Definitely don't want moisture getting in there.
