RodLS
Added PIE adapter and Lloyd Rubbertite floor mats.
I have THX/NAV. It was to add an auxiliary plug.
It could be the wiring to one of the wheel speed sensors. If the wiring is starting to fail, the sharp turn could have moved it just enough to cause a problem. You could try making a couple of sharp turns to see if it happens again. Also, on some cars these codes will be saved in the computer even after they've cleared. The dealer may be able to read the saved code.
It's a nice and warm 35 F here in Norfolk, but it's still too cold to wash the car. I usually take it to one of the automatic car washes where the vacuum and hand dry in the winter. After trying several places, I've found that they leave a lot fewer swirls than anywhere else (including a hand wash where the owner showes pictures bragging about the show cars he's detailed, then returned my car looking like it had been dried with sandpaper).
is it the frdn-aux/s?
frd03-aux/s
That works on the '06? I thought the correct adapter was the FRDN-AUX/S.......
the speaker is "Made in USA" but the quality is worst than "Made in China". It's made of paper and the paper cone (WTF!) The picture doesn't do justice but the paper just warped over time.Ya its working just fine. I looked back at some old threads and they all said FRD03-AUX/S.
http://www.lincolnvscadillac.com/fo...for-06-w-THX-Navigation&highlight=FRD03-AUX/S
did a quick swap with my rear passenger side speaker, here's what I found; the speaker is "Made in USA" but the quality is worst than "Made in China". It's made of paper and the paper cone (WTF!) The picture doesn't do justice but the paper just warped over time.
So is this what we're paying for a 35k car?
I got stuck trying to drive up my driveway in less than 1" of snow. Reminded myself to throw the sandbags in the trunk.
Yes. ALL LSes have paper speakers.....
Nothing wrong with paper cones. Some of the best loudspeakers ever made use them.
In a moisture laden area like the inside of a car door???
Mine still sound great
An engineer decided to put paper cone speakers in the door...![]()
The base audio system is made of cheap paper and it's not sealed, that's why it sounded like crap. I have 3 other cars that are all using JBL premium sound so I know the difference. So I went to the bone yard today, found 2 2002 LSes that were a week old (wrecked) Removed the premium door speakers from the rear and they're all sealed (same with the front) I also tried removing 2 of the rear subwoofers but damn those are made of cheap paper too and it's worthless (cracked) Luckily the other one has the Alpine aftermarket speaker, it's made of polymer and still looks good. Didn't realized I spent $40 for all 4 speakers today, plus I was able to get ahold of the stock sub amp for $10 too. This is my Black Friday deal! hopefully things will work out well.
How did you know that your base system is sealed? A grill doesn't make it sealed.Well, I have a 2006 and mine are sealed so that may make a difference. I have the base system.
No... A bean counter decided to.....
