2002WRXSTi
EPIC FAIL but installed the new Brake Rotors and Pads at least.
Got home around 4pm or so after I rented the ball joint tool from Autozone. Lift the Mark up and blow the drivers side apart. Put Ball Joint tool on and am cranking the thing till I am afraid it is gonna break :Bang
Back off on the took cause I just couldn't get the ball joint to unseat from the control arm and was afraid of mushrooming the end. Then I wouldn't be able to put the nut back on and my car would be stuck sitting on jackstands in the driveway.
Put nut back on and left the old ball joints in. Then put on the Brakemotive Drilled Slotted Rotors with the Metallic pads. Took it for a spin around the block to test the brakes. Made a ton of noise at first but then on the back of the block everything got nice n quiet. Plus now it stops like a performance car and I haven't even broken the new pads in yet
