dnsherrill
i'm still wondering what this is tho, doesn't the air shock take just 2 lines? air and sensor?
do you think it used to be here?Your CC switch should be right there by the ABS module/pump, which is also the area the smog pump is.. forward of wheel, in the driver side of bumper.
-----If you look at these ones look at upper right corner and you can see plug end that yours plugs into.
Ok that connector goes on the AIR BAG soloniod and the line feeds air to the solonoid.-----
then this connector on the left is for something else, not the sensor
yes, '96....I know there are some good mechs at some dealers and I have no doubt you were one of them DD. These guys here in Woodstock, Ga are Stealers.What year is the car we are discussing here? 96? T
I love how people just think the dealer is out to f*** them. I know that some people are idiots, but that doesn't mean the whole dealership is bad. I worked for 5 years at Ford, I had a lot of pride in my job. I sure never went out of my way to screw up people's cars, like most people seem to think they do. I was usually the guy people were grateful to because I fixed it right the first time, after multiple other dealers gave them the run around.
----You need someone with a 96 to take a pic of that location on a non-tampered with car so you can compare and ask the dealer why they were even in the LF wheel well.
That "don't come back" stuff doesn't fly. You need to speak to the dealer's service manager and get your damn relay back! Don't mention that the code was previously intermittent, just say you had the code after they fooled around in the wrong place and found the relay was missing.
http://www.mysporttrac.com/~library/26079/New Tech Folder/05S28 Cruise Recall.pdf
kind of....however,Ok now with all info in hand this is what I figure is going on.
Let me know if this sounds correct.
noYou took air ride off this car. Did you pull the pump on pass side?
I'll take a closer look when I take it apart again tomorrowAlso that area where relay was looks like its been gone for awhile by the look of rusting on bracket?
definitely yes..clicked, locked in place...what conclusion do you draw from the locking tabs being in place?Also are the LOCKING tabs on the 2 wire smog connectors still all there?
