2002WRXSTi
That's not where you install them
2002WRX- Of course its going to show 0mpg if you're sitting still, the car knows its not moving
Meant 0 Miles Left as it had started at 10 miles on a 2 mile or so road, not 0mpg.
I drove mine over 40 miles once with the gauge on "E" and the computer telling me I had an empty tank and 0 miles left![]()
Drove to my friends house half-mile away and car felt strange and made a funky sound on the throttle. Sound was coming from the passenger rear
Get out of the car tires half flat :shifty: Come out a half hour later tires completely flat bead popped. Jacked the car up, pumped up the tire and the tire has been fine since. Trying to figure if it's a bad spot on the rim or what?
I have a spray bottle with some Dawn dishwashing liquid in it that I use to spray tires when I am looking for a leak. Worked on my 44 Bogger SwampersWhen I have a slow leak, I back down the boat ramp to get the tires in the water a bit to look for leaks. I've had several plugs in the past stuck in tires that I did right on the car after finding holes that way! lol
Also, yesterday I put a set of Bilstein shocks that came off a 2009 Toyota TRUCK on the back of the Mark. It rides AWESOME, much better than the wishy-washy way the Mark butt used to float around - it rides more like my TBird now (flat, sure-footed, stiff/sporty feeling).
Just finished installing a new P/S upper ball joint boot and re-greased the heck outta the ball joint. Also found out that I have some belts showing on the inside edge of my front tiers![]()
How did you regrease them? That is if you had stockers or Moog replacement UCA's?
Mine are Moog and they came with grease fittings. Unfortunately, my LCA's are a different story. Moog but with no grease fittings. I'll have to drill them and install fittings before I install them. I don't like using the needle fitting for the grease gun if I can help it.
Really? The ones that I have been getting or that are on my car are the non grease fitting type and I am a bit pissed that I have to instal fittings.
I dunno. Guess I got lucky. I've heard that it's pretty much random. You may get a set with or without fittings. Depending on which box they pull off the shelf that day![]()
Drove my new 97 blk on blk LSC from North Jersey to North Port Florida. The car sat for three years. Changed the oil and drove 1600 problem free miles. Air ride worked perfect! Now for a new paint job and tires that were made this decade.
