I have a problem with the “Memory seat, steering wheel, mirror and pedal function” on our 2006 Lincoln LS V8. Every thing can be set as per Manuals instructions but the only thing that responds are the pedals, wheel and mirrors, the seats do not respond when #1 or #2 button is pushed on the Memory switch. Every thing works with each individual control switch. Also with Shops scanner all functions can be checked using actuation tests and they respond. Has anyone had this happen and found and cured the problem? No codes. Thanks
