Don Pfau
I would like to find 2 17" x 6"-7.5" wide Cobra R's to use like skinnys for the front when I go drag racing. With the standard 4 1/4" bolt pattern for a Mark VIII. I would prefer chrome ones.
Didnt Driller run spare tires up front for a bit?
Meh. Tamato, tomtucker.Wheels, not tires.
I spoon fed this to you once already. www.weldcraftwheels.com
They will narrow any wheel you want. Or widen it, if that is what you need.
I've seen that and its a great idea. If I'm not mistaken the Mark spare is even Aluminum. I just wanted somthing that matched better and looked better if possible. Thanks may end up doing that though. DonDidnt Driller run spare tires up front for a bit?
I've seen that and its a great idea. If I'm not mistaken the Mark spare is even Aluminum. Don
Not interested and I do not need to be spoon fed by you. I'm looking for a inexpensive solution. Not a way to take a expensive wheels, pay a lot for two way shipping and pay even more for the modification. Thanks but no thanks.
Not all are aluminum, but they are out there.
I've seen them stripped and polished and they don't look bad.
I believe certain SuperCoupe aluminum spare wheels work as well and when they are stripped and polished, I think they look good.
