Lincoln ave
missing I have a hood i will sell you also, actually several of them let me know when you wanna start cutting. I could use a few extra bucks. Good luck
How much for a hood to 06066? residential
I did some measuring and did some picture taking of my wiper cowl as I have it off for a possible repair of the coolant bottle or hoses.
Anyways, I took a good look and there is clearance inside the hood for good ventilation into the cowl. I have some vents I could use to make some custom little vents that fit flush. I think it is definitely possible and could be good for heat removal.
The orange squares are roughly the straightest parts of the cowl surface.
I am going to do an experiment while I have the cowl off and do a test drive and temperature taking while the cowl is removed (mimmick of having the vents); then do a drive with stock cowl in same conditions and take the temperature while driving.
I will use this data to see if it is even a difference that is worth the mod.
use fog-X on the windsheild
and the heat would greatly help in winter too :-D
