MarkVIIIS
Wuts wrong with the boost a spark and wuts does boost a pump have to do with it, I figured it wouldn't be worth putting a bigger throttlebody on. Wut do u think about intercooler options
KB makes both and the Boost a Pump works well yet the Boost a Spark does not. Thats what I was saying. If you run to near limitson your fuel system then you may want one. The Boost a Spark though is useless. All it does is give the coil more feed voltage and in theroy it makes a hotter spark. Well on multi pack systems it dont make a difference. It will just burn the coil faster. If you have spark, you have spark. It MAY help if youare blowinghe spark out but you need to be close to 20psi before hat is an issue.Wuts wrong with the boost a spark and wuts does boost a pump have to do with it, I figured it wouldn't be worth putting a bigger throttlebody on. Wut do u think about intercooler options
Heres my pathetic dyno results
Yes that seems low??? I wanted to wait till I had exact numbers for mine before I replied. But I'am just not there yet, but close. Installing a meth/water injection then it's ready. They say a stock Cobra like mine Dyno's around 370 RWH stock and my mark has more pull than the Cobra did stock. It doesn't now because the Cobra is no longer stock. Will compare with you as soon as I get any concrete numbers.
Ok I finally got my oil pan done and I got a smaller belt and they car has no belt slip anymore. My problem now is my check engine light has been on an it was before with my last tune with codes for both banks running rich now the codes are for bank 2 running lean and bank 1 running rich now I don't know if that could have to do with the tune or if my o2 sensors are bad cause I don't understand how one side could be lean and the other rich unless I have a bad fuel injector or something and now I'm afraid to drive with it running lean. If anyone has any ideas please let me know.
