96_Lincoln_LSC
here is whats has been done so far, New radiator hoses.. BTW good luck finding Factory hose's for this now as no aftermarket supplies them, Google no longer lists the hoses either and Ford lincoln dealers across the US no longer stock them or list another part number for them...
I took my hoses to a local shop who sells Good year hose's and was able to match the bends perfectly to different hoses and was a little longer then the orginal, so a little nip here tuck there and Im back on the road. now secondary to this, my car is still overheating running hot. I have removed the T-stat, flushed water from my hose and forces it to backfill into the resivoir bottle till no more air emerged.
crank up the car and turn on the AC to max, car idles no issues, runs perfectly fine ice cold AC too. car temp never exceeds middle even with t-stat removed. Cooling fan comes on as soon as temp gets to the middle of the gauge. or when the AC is on. tested both ways. so we are confident the Cooling fan is not issue. also tested coolant for hydrocarbon (exhaust Gases indicating blown gasket or head cracked- This is negative ((good not blown head)) ). ran the car over 1 hour with out incident (idle AC on) no increase in temp. Run the car to work this morning and sure enough if i didnt turn the heater on full blast it would have spiked it again. we even pressurized the system to 15 PSI ran the car and then burped it to see if there was a trapped bubble in it, it still seems to be getting to warm. also replaced water pump 6 months ago, radiator is 3 years old, and checked temp on radiator both tanks evenly heated as well as the very top of the radiator and bottom as well. We figure its working correctly and not clogged.
I am at a loss as to where else i need to look. is it possible there is still air trapped?how to get it to burp since there is no t-stat in it. should i remove the lines to the heatercore and try blowing water through that to insure its not partially blocked or air trapped in it?
it acts like there is an air pocket that superheats forcing water back out as it steams up...
