So now onto putting in all the speakers! This is the part we've been waiting for!!!
So, you're gonna need an Amp kit, unless you're not putting in an amp which i strongly advise you to do. As would probably anyone else who knows their way around a car sound system...
and that looks a little something like....
So now just start running those wires from the battery to the amp. We are fortunate enough to have a car that has the battery in the rear, so if you're just mounting the amps on the backseat you're gonna have a really easy job.
Now put those amps where you want them to be and just start connecting. Battery wire to battery spot. And ground spot to ground. (By the way, we grounded the wires to the wheel well cause there's a whole lot of exposed metal there. so that might be your best bet honestly.
important note about this though. Do NOT mount those amplifiers yet. It's not a good idea because you may need to move them around. Although, it would be smart to know exactly where they're going to go so you can have the cleanest install possible.
Now, i put 5x7's in all of the rear factory openings and i put 5 1/4 components in the front doors. And contrary to what i've heard some people say the rear deck IS 6x8. Not 6x9. If you don't believe me then head over the crutchfield and they'll tell you.
For those who don't know this, 5x7 speakers fit into the same holes at 6x8's. So i just opted for 5x7 because i've heard JL audio is great.
So for the rear deck, just start tearing out all those wires and speakers and everything. And you'll end up with...
And then just take your terminals or if you prefer to solder that's probably better and just connect the wire to those speakers and you're all set to put it back in.
Now onto the rear doors. It's pretty much the same, although running the wire isn't the most fun process in the world. But in the end it's worth the hassle.
and that's what it's going to look like with the new speaker in the rear door. Connect them and screw them back in and you're set! That wasn't that hard, was it?
Now moving on to the front doors. Since there are factory 6x8 openings i had to get an adapter plate to fit my focal components. Not a big deal.
So just do the same thing that you did with the rear speakers and just screw those front speakers in. (By this time, my camera had died. So i didn't get a chance to get any pictures of my Focal woofers in the door. But if you want to see them just let me know and i can take my panels off and take a picture or two.
So, initially since i was planning on putting a double din in, this is the metra kit, which by the way the model number is 95-5000B.
I've always been a big fan of metra and would recommend them over schosche.
If you can see the texture in that picture it basically matches the texture of the factory trim which is good.
So after this, you've just got to put your kit on and screw the climate control back onto the bracket with the head unit. And now you'll just have a big hole. So start connecting your head unit and just put it in there!
Now to all your guys that were asking what happened with the double din, here you go.
If you can see how uneven that trim looks on the side it's cause we were sanding it and that just looked really bad. and on top of that that's as far as the receiver would go in. So it just wouldn't have been a good fit. Most people haven't had any problems with Alpines or Pioneer or other more reputable brands, but for some reason I had a HUGE problem with this one.
Now, this part is optional, but i HIGHLY recommend it.
SUBS!!
The subs I have are a good example of quality subs that you don't have to spend 600 dollars on cause some people would rather spend that 600 on some quality speakers or maybe you just don't have 600 to spend!
For subs, the bigger wire you have the better. So i'm very glad i got that 12 gauge even though some people may say it's overkill.
Tired yet? I am, and all i'm doing is typing!
So just stick those subs in the trunk and wire them up!
Now, we tried to be smart and wire the remote wire (which, by the way, is the wire that tells the amp when to turn on) to the fuse box in the rear. Little did we realize that there's ALWAYS power to the rear. Yes, we're that smart. So after a few minutes of contemplating we just decided to get over it and wire the remote wire to the head unit like we were supposed to!
And voila, we had ourselves a new sound system. Well, almost.
We also had to wire up those tweeters because we had a component system.
Thank lord for FOCAL because they included tweeter pods in the package! So we were going to drill holes and mount them, but we just decided to take the lazy way out (which is never the way to do things) and use automotive grade super glue to mount them to the A-pillars. I don't have pictures of this yet because I still have to put in my new head unit cause obviously that old one looked terrible.
So i'll put up some more pictures of all of that later.
And by the way, don't forget that you shouldn't put your door panels on until you have absolutely everything wired up to the amps and you test out your system and personally see that every single speaker is working.
Now you just need to set the gain on your amps and if you have subs then you may want to use a high pass filter. It dramatically improves the quality of your sound because your speakers are not trying to do too many things at once. They can just focus on leaving those lower notes to the subs in the trunk!
And NOW...voila, you've got yourself a new system.
I would recommend using zip ties to tie all your wires together to make it look as clean as possible. And that's basically the gist of it all!
Hope you enjoyed my write up and if you ever have any questions feel free to message me and i'll do my very best to help you out, as i'm sure anyone on this forum would.
I will have After pics up by tomorrow when everything is cleaned up and the new head unit is installed.
Sincerely,
S
