The Metra Axxess ASWC Steering Wheel Control detects some of the new Kenwood line of HU's as JVC (thus nothing works automatically via auto-detect).
I have read that you put a resistor between the ASWC and Pin14 of the 20-Pin car's harness... in the White/Green wire, then it will auto-detect Kenwoods correctly... then you remove the resistor. I have read that it needs to be a 12,000 Ohm resistor (also read it needs a 10,000 Ohm, and read that it needs 1200 Ohm resistor). Seems like the common agreement is that it needs a 12,000 Ohm (12K) resistor. I went through all my resistors and could only come up with or make: 10,000 or 11,000, or 11,200 or 11,500 or 12,200 or 12,500. I didn't want to take it out and rewire it anyway.
After much reading here is how to manually program the ASWC. I have made this much shorter than the manual. I documented it for a Gen1. You can manually program it for a Gen2, but use the manual. The Gen1's have less buttons on the steering wheel than a Gen2, so the programming will be slightly different.
Metra Axxess ASWC manual programming for Kenwood HU's on a Gen1 Lincoln LS
Start programming process:
Press and hold the reset button down for more then 10 seconds until slow constant flash on the ASWC.
Button Programming:
1) Press and hold Volume Up for 7 seconds until solid Red.
2) Press and hold Volume Down for 7 seconds until solid Red.
3) Press and hold Volume Up for 1 second until the LED comes on.
4) Press and hold Volume Up for 1 second until the LED comes on.
5) Press and hold Media for 7 seconds until solid Red.
6) Press and hold Mute for 7 seconds until solid Red.
7) End of "button" programming: Press and hold Volume Up for at least 10 seconds until a slow constant blink.
You are now going to program the brand of radio HU.
Radio ID Mode:
1) Press and hold Volume Down for 5 seconds until the LED starts to flash quickly.
2) Press and hold Volume Up until the LED goes solid Red.
3) Press and hold Volume Up again until the LED goes solid Red. You have now programmed a Kenwood HU.
4) Press and hold Volume Down for at least 5 seconds until LED flashes.
LED should flash twice indicating Kenwood Radio, then the LED will go solid Red indicating programming complete. Done.
If you need to start over, start at the top by pressing reset for more than 10 seconds.
Metra Axxess ASWC instructions:
http://assets.sonicelectronix.com/manuals/metra/aswc.pdf
Resistor info:
http://www.diyaudioandvideo.com/Electronics/Color/
I just did it and it worked the first time, took less than 5 minutes. It's very easy to do.
(It took hours to research the resistors and reading etc... glad I came across how to manually program it, as it's much easier than doing the resistor method, once you figure out the steps).
