The plan was to spend close to $3000 for a forged rotating assembly. The rods will be balanced as well as the crank. I will prolly go with the DSS or Mod Max kits.It's not a tiny bit. The forged crank(which is entirely unnecessary for anything under 450-500 HP), rods and pistons is only one level. To get to the next level requires a whole 'nother step up, including balancing, even better rods, pistons and fasteners. Probably almost 4 grand in the rotating assembly alone without labor, easily double what you could go do yourself.
If I am throwing forged pistons and rods in the motor then it seems half assed to me to reuse the cast crank.
Now for you to really freak out....... I wanna put it together myself! I have watched 100's of engines being put together and 8 or 9 4V mod motors and I just wanna do it.
I have built several rotarys but those engines are childs play by comparison. I will take the block and heads down to check mating surfaces and if any honing is needed of the main. I will get the tool (cause I like tools) to change out the lash adjusters and replace the springs with Comp springs. I will file fit the rings and line them up per performance recommendations, use new ARP bolts/stud EVERYWHERE, slap the heads on then drop the motor off at Gear heads Performance to have them work their cam timing magic on it then drop it back in the car.
I also (per peoples input on here) step up the CR to 9.8-10.2:1
Mike, when the car has that motor in it I will long have had a different DD. The car will be retired to "Toy" status when that motor is done. At that point I will run 400-420 rwhp until I get bored with it or blow the trans. After then I may sell the blower and do a C head swap and add a manual........ not sure what, gotta see what fits best as I want it to look stock.
As for the blower, I may be wrong but I think the KB case has the same bolt pattern to bolt to the top plate as all the others.......... BUT, it prolly still wont work cause I believe the 2.2L "C" head kits snout is much shorter.
Don't matter. To finance the C swap the KB would have to be sold anyway.
