Screw-Rice
Tirerrack.com
Tirerrack.com
Well I would agree but you bought my Gen 1 soYet one more reason for Gen1 dominance.
not that i recommend it, but just curious, would running a few pounds different air front to rear prevent this?
Oh JOY!
Yeah so I went to the Pep Boys over in Edison which was quite a drive cause no one had the same size tires I had installed in the rear.
So I told the guy I needed tires to match my rear tires size. I walk out to see they put the new tires in place of my rear tires and left the bald front ones
Tell him the mistake so they go to rectify it and you can see what wound up happening
are they directional tires? if so time for them to remount them again
Yup they are!
I spent way to much time there so I had them just put all the rims backwards so I could get the hell out of there already!
fukk that, go in bitchin how you want it done right it only says what side they go on on the inside of the wheel!
My only thing is I don't feel like driving all the way to Edison to have them fix it? I wonder if I can go to the one by me and have it done or not?
I agree. I would assume they would, if you show up with your receipt and explain it to them.
he probably thought it was fwdYeah not only that but I had Mud and Snow tires that they took off he advised me to use on the front?
I didn't want the Ventus tires on the back cause they don't seem Snow friendly
I've got staggered size wheels and tires. All 18", but the rear wheels and tires are both wider than the fronts. I've got 245/45/18's on the front 18x9's and 285/40/18's on the rear 18x10's. Overall circumference is off by .9", height is different by .2", and I have no problem whatsoever.
So I finally got off my somewhat lazy ass today and polished my headlights. Of course I was to dumb to take a before pic so take my word they were yellow and ugly!
So I used the 3M kit with the various sanding pads, a polish pad and then a foam pad you use there compound with. All in all it was fast to do but I will see how good it worked tonight![]()
Hose clamps?? Or what looks to be a Caulk like substance???
Whats smeared around the other hose? Red RTV??
