I figured it was going to happen... Air ride problem. My bags are 3 years old, and don't leak. I can tell you this is true as my front end is so high right now, I'm waiting for them to explode.
Here's what happened. I came off the highway, and heard my compressor kick on like it does to raise the car. Then I notice it keeps turning on then off, then on again. The "Check Air Ride" warning message came on. I pull over, the car is sitting fine. I switch the system off, then back on. The compressor kicks in and keeps pumping the car up in the front. I turn the switch off, then the compressor stops. I flip the switch on, then remove the key and shut the doors. Only the rear vents. Not the front. I limp the thing 30 miles home, bouncing all over the place. The car looks like a ghetto car ready to hop up and down. I've read some of the other posts here. My compressor is really loud now. It won't shut off as long as the key is on, and the switch is on. The rear system seems to work as it should. I did have a massive amount of leaves on the car today, what plugs the compressor? I'm guessing I'll need to go get the wood laid to me at the dealership for diagnosis, but I'm hoping one of you fellas can hep me out. Thanks.....
FYI my air ride is stock, not adjusted, lowered or messed with. Just new OEM bags on all four corners 3 years ago per PO's paperwork.
Thanks,
Thanks,
