what all did you do to yours?
r u srs?whats the j mod?
a jmod is a seperator plate in the trans with certain holes drilled larger for more line pressure, basically a shift kit you can do yourself and it saves the trans life.
Don't forget about getting a one piece drive shaft when you move to the taller gears.
Or you can be lucky like us with our 93's and have one already.
He never started. He just..... is.Even you started as a nOOb.
