what all did you do to yours?
r u srs?whats the j mod?
a jmod is a seperator plate in the trans with certain holes drilled larger for more line pressure, basically a shift kit you can do yourself and it saves the trans life.
Don't forget about getting a one piece drive shaft when you move to the taller gears.
Or you can be lucky like us with our 93's and have one already.![]()
He never started. He just..... is.Even you started as a nOOb.
